Fuel Pressure Regulators - Good or Bad?
What's the go with return line?
The FPR is vacuum driven, which sounds like a cheap way of avoiding PID on the pump.
If you were to remove the FPR, block the return line, I suppose a static pressure sensor on the line would be needed and PID control to adjust the pump speed to suit.
Which then gets to my question: Would switching to a returnless fuel system deliver savings (or possibly consume fuel due to possible greater fuel pressures and therefore more fuel injected?)
