That won't be the case though, with the return unchanged, all will happen is the pressure differential will drop and so the injectors will flow less.. return line still less resistance than the restriction though the injectors.
The only way it will work I think is to go all the way to a return less system - or dropping pump speed minor amounts. There'll be some savings in the pump speed somewhere - it's a continuous drain to maintain the pressure it does.
