The tires! The tires! Either get RE92's or pump them up!
Do you still have the spare and jack in the car? Every bit of weight loss is a substantial % of the power to weight ratio compared to a 3,000lbs+ car. Better hill climbs, and better mpg. That should free up space for the battery.
Grill block helps a lot on aero. Do a warm air intake as well. You probably want to keep your wipers on in Canada. The "Nut" will give you the most gains.
I try to be helpful. I'm not an expert.
