Old 09-13-2013, 11:44 PM   #70 (permalink)
RiderofBikes
Pantry Boy Supreme (pbs) - '04 Volvo S80 T6 Premier
Hotter during closed periods... period. Cloth interior absorbs the heat more, while leather or anyother reflective type material will reflect it onto other surfaces and prevent heat build up in the cushioning, with that said, yes shiny material will burn the crap out of you, it is also easier and takes less time to cool the surface. The light fabrics hold in heat, as well as your body heat, and while your sitting in the seats even with the A/c, your contact with the material is trapping heat inside the cushioning...
I've been a car detailer for a month now(Budget rental), and we always leave the windows down when que to be cleaned, when we get in, we roll up the windows and crank the A/c, let the car continuously run until were done and park it again.(which at that point we leave them up) ready for customers
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
