Old 09-14-2013, 08:46 PM   #4 (permalink)
paintme205
nadia - '03 ford mustang mach1
90 day: 18.47 mpg (US)
Jasper - '11 ford f150 xlt ecoboost
90 day: 18.71 mpg (US)
Festy festiva - '91 ford festiva L
TEAM FESTIVA
90 day: 55 mpg (US)
Originally Posted by Awd180 View Post
Start with engine maintenance, a 22.5 year old car is more like 23.5yo car. Check all your hoses, replace belts, including timing belt, water pump, clean grounds, and most of all the valve cover gasket is the easiest fix. If it's really the head gasket it isn't that hard on that engine, replace gear fluid also. You'll benefit more there first, Cd is not a constant but varies as a function of speed, if most of your driving is less than 55mph you'll see less from aero and more from mechanical. imo
Maintenance and cleaning is my first priority. I'm going to replace the valve cover gaskets and timing belt first thing. If I see any signs of head gasket issues, I'll just rebuild the whole thing.
It still has the original 12 inch rims. They have pretty good tires now but supposedly everyone upgrades because tires are hard to find.
