09-15-2013, 04:31 PM
Bu - '08 Chevrolet Malibu LS 90 day: 32.29 mpg (US)
Attack of the Triples!
GM 1.0L turbo sidi
General Motors Europe ... at the 2013 Frankfurt International Motor Show (Sept. 10-22) ... will unveil its 1.0-L, three-cylinder turbocharged gasoline engine. ... It's a modular design which, in 1.0-L form, will deliver 84.6 kW (113.4 hp) and 166 N·m (122 lb·ft) from 1800 to 4700 rpm
the 1.0-L is the initial member of a modular family of three- and four-cylinder units ranging up to 1.6-L, a portfolio that mirrors Ford's EcoBoost family.
Fuel consumption is claimed to be some 20% better than that of the 1.6-L naturally aspirated engine used in the company’s Astra models.
During bench testing at WOT, the new triple demonstrates lower noise levels across the rpm range than similarly powerful gasoline turbos up to 1.6-L, GME engineers claim. Because of this, the level of additional in-car sound insulation is significantly reduced, and complex engine mountings and subframes are not required.
Full article: http://www.sae.org/mags/sve/event/12380
“Soft shapes follow us through life. Nature does not make angles. Hips and bellies and breasts — all the best designers have to do with erotic shapes and fluidity of form.” - Luigi Colani
