At 1.5 l and 3 cylinders, i'm sure it should get good mileage if you laid off of it.
I'm surprised it even is a 3 banger. With 3 cylinders there's a "time space" between each cylinder firing which isn't ideal for power or refinement. A 4 cylinder will fire at the end of the last cylinder firing, most everything else has a firing overlap.
I try to be helpful. I'm not an expert.
