Old 09-15-2013, 10:00 PM   #95 (permalink)
TurnNBurn
Update: got the motor mounted and will post pictures of the stripped frame and the motor mounted. However, the rear sprocket is stock and the chain doesn't quite clear the rear frame. So a new 72 tooth sprocket has been ordered and that should raise the chain up enough to clear the rear.
Pictures will be posted throughout.
Also, I've settled on the battery, but in the meantime I'm buying two 12v lead acid batteries while I build the electrical systems (headlights, turn signals, etc...) and get a feel for the bike.
