The weldable 1/2" steel tube frame is primarily wanted because the whole thing will articulate for trunk access, so I want it somewhat stiff and tough.
Stiff and tough because it will alligator open?
Consider putting it on a 4-bar linkage. Then it will be held at four points instead of two so it won't get racked so much. The lower arms would want to be about as long as the decklid and the upper ones shorter.
Then use the decklid to replace the two bottom bars.
