Originally Posted by andyn666
no not imp. mpg us mpg getting nearly 52mpg imp
I'm suitably impressed
I will definitely be fitting the switch to try it out, during temps below 15c my engine can take 20mins or more to heat up!
Just make sure it still cuts out in due time, when you force it on earlier than Ford intended it to be on.
20 minutes to heat up is an awful long time.
Trapping the heat / keeping the cold out also works wonders - it's a side effect of a grille block .
