Originally Posted by mikeyjd
Ha! I log mine with my phone before I leave the station
1. Pull up to same pump I always use, unlatch fuel door
2. Insert fuel nozzle a very specific way, pump at the same lowest flow setting
3. Pull out smartphone, load ecomodder garage fuel log
4. Monitor gallons used intensely, with fingers ready to enter in the numbers!
You
know your an Ecomodder
if... You are the
only person at the gas station performing a celebratory
fist pump as you complete your MPG calculations
