Originally Posted by JRMichler
More likely "Injector Clog".
You'd like to think that, but the fact is, bad gas is still has the same lubricity, and still cleans up coke and tar from additives. We've been using it for years to clean up other oil based products. Once the dirt and stuff is out of it, there's nothing in the gas that will coke an injector any faster than 'clean' gas straight out of the pump. All that's missing from it is the normally low spirit content anyway.
At this point, I could mix it with some methanol and 'renew' it, but I'm not buying a 55gal drum of meth to do that when I know it works fine as-is.
