Old 09-18-2013, 04:17 PM   #20 (permalink)
andyn666
Outlander - '21 Mitsubishi Outlander PHEV Design
90 day: 412.06 mpg (US)
Well i took it for a drive and found a few things;
Outside temp was 11c, coolant temp started at 18c.
The heater started up straight away and took 7 minutes to heat the engine to temp and cut out, I assume it took longer than at idle due to the air flow into the engine bay. This morning on my way to work it was about the same outside temp and took about 25 minutes to warm to temp.
One thing I did notice was the heater started cycling on and off while i drove it so it would seem while i hypermile my car it doesn't put enough heat into the system to keep the coolant above 85c!
If it has electric coolant pump (probably has) and you can start it without starting engine, you have successfully converted supplemental heater to parking heater (ofter only difference is in software and dealers take money to convert it to parking heater)! Very good. You should start it 5-10 minutes before you start car engine - no more cold starts.
Luckily it does have an electric coolant pump, and fortunately the system the heater uses is so simple it can be started just by turning the ignition on for a few seconds while switch I've add is on, so yes your right i now have a parking heater
Andy
