Old 06-27-2008, 10:52 PM   #4 (permalink)
reformed
Did you get that thing?
reformed's Avatar
Green Machine - '92 Honda Civic LX
90 day: 39.98 mpg (US)
Money pit - '97 Infiniti j30
90 day: 22.74 mpg (US)
Originally Posted by SVOboy View Post
Hmm, I was assuming there was some sort of ecu output for it...
I think you assume correct. I would assume its just an output that you can place a bulb inline with and run the other side to ground. If you don't get an answer here, a shop manual for the VX should tell you what wire it is off the ECU and possibly what voltage output it is. I do have access to one at work, so if I remember tomorrow, I'll look it up.
