Old 09-18-2013, 11:55 PM   #317 (permalink)
101Volts
101Volts's Avatar
Woody - '90 Mercury Grand Marquis Wagon LS
Last 3: 19.57 mpg (US)
Brick - '99 Chevrolet K2500 Suburban LS
Last 3: 12.94 mpg (US)
M. C. - '01 Chevrolet Impala Base
90 day: 18.73 mpg (US)
R. J. - '05 Ford Explorer 4wd
90 day: 16.66 mpg (US)
I tried using marine plastic as smooth wheel covers and as an air dam, but the plastic formed holes when I heated it. It should have been nice and tight.
As long as your plastic is tight, you should be good to go.
Thanks.
Father heated plastic that was on a hubcap too and it formed holes.
Though it's been changing form, The plastic has held until the last time I checked it at least and I didn't see any problems worth fixing so far.
The Following User Says Thank You to 101Volts For This Useful Post:
aerohead (10-11-2013)
