Old 09-19-2013, 06:19 PM   #4 (permalink)
slownugly
Burn lean and prosper\\//
VLX - '93 Honda Civic VLX
90 day: 51.1 mpg (US)
i got 46mpg in a 95 sedan with a y8 in it.
the problem with running an auto with a z1 is the gear ratios might not be in the optimal range since the vx trans is geared for very low rpm. the rpm ranges you would be in might not even be optimal for lean burn. what was the cruising rpm at say 70mph? i guess it depends on the jdm ecu parameters as well. if the jdm auto transmissions gear ratio is different than yours i would shy away from that.
Burn lean and prosper \\ //
