Originally Posted by cbaber
The JDM didn't receive the D15Z1 motor, so there is no automatic ECU that can control the D15Z1 and automatic transmission. Their lean-burn engine was the D15B 3-stage VTEC, which is a different design than the D15Z1. So it looks like if you want to go auto, you can't go with the Z1.
I don't see a reason to downgrade to a B7 if you already get good numbers with the Z6. It was only more technically economical because the M/T gear ratios for B7 motors were taller than Z6 models. SOHC VTEC combines good fuel economy and torque down low, and more power in the top end.
![](http://i88.photobucket.com/albums/k171/JDMENGINEDEPOT/ENGINES/HONDA/92-95%20HONDA%20CIVIC%20D15B%20VTEC-E%20ENG%20AND%20TRANS/IMG_0246_zpsc2fa5e05.jpg)
Thats an obd1 JDM d15b, which is a d15z1. The ECU is a p84-901 or the p07-900.
This is a 3 stage which was only obd2 I think?
![](http://i755.photobucket.com/albums/xx191/jdmcars/1JZGTE/IMG_2763.jpg)
