Originally Posted by HypermilerAX
Or 215/60 R16 A-rated. ![Big Grin](/forum/images/smilies/biggrin.gif) Should be about the same diameter than what you have currently (235/35 R19?) with reduced weight and CdA and top RR. Four of these can still handle 2760 kg load.
I will note this as and when I ponder tyre replacement. I am where I am at the moment so I need to work with what I have. The biggest mod is technique so I need to learn "how" more.
That seems short-geared for 2.7 TDI. Only 120 mph at full rpm ? (4k on a TDI?)
I said under, it is also under 1500
![Cool](/forum/images/smilies/cool.gif)
and at 90MPG + on the flat.
@Xist & 320Touring -
