Old 09-20-2013, 05:34 PM   #5 (permalink)
cRiPpLe_rOoStEr
Originally Posted by UFO View Post
What about extending the intake duration into the compression stroke? Would this be a cam used in concert with a high static compression ratio to get the more efficient power stroke without the detonation issues of high intake charge compression?
That's the most usual setup in the current generation of hybrids. So-called "Atkinson cycle", altough it's not the real Atkinson which actually uses an articulated crankshaft to provide a power stroke longer than the compression stroke. Before hybrids got mainstream, this setup was quite popular in stationary and marine engines, coupled to a supercharger to overcome the discompression generated from the longer intake timing, in the so-called Miller cycle.
