Old 09-20-2013, 07:16 PM   #7 (permalink)
some_other_dave
Originally Posted by rabbit640 View Post
Apparently, you multiply your compression ratio by 10 to find out your maximum efficiency octane.
Compression ratio is only one factor in what octane fuel you need to run. There are lots and lots of other factors, from combustion chamber shape, to spark plug choice, to cam grind, to how good your cooling system is at preventing hot-spots, to if you are running boost.... No simple calculation can take those into account, so that calculation above is little better than a SWAG.
-soD
The Following User Says Thank You to some_other_dave For This Useful Post:
Ryland (09-20-2013)
