Old 09-21-2013, 06:54 PM   #9 (permalink)
deejaaa
Not banned yet
deejaaa's Avatar
getto - '02 Volkswagen Jetta GLS TDI
90 day: 53.82 mpg (US)
Blue - '03 Chevy S-10, LS
ended up blocking the 2 lower openings a few weeks ago and today put in the HID's and added some covers for the openings between the skid plate/front dam to smooth the flow some. will see tomorror on the way to work if it makes a difference. plastic came from a mud flap that i picked up off the side of the road.
here's the pieces installed on the bumper cover:
best shots i could get:
need to get it on ramps, drill a hole and bolt both of the corners to the skid plate so they won't be hanging so low.
openings closed:
i reinstalled the rear flat deck fin, boxed the rear somewhat.
this is the best i could do at the moment but i will try to make the transformation a little better when i get the chance:
FOR SALE: 02 TDI Jetta- 5 sp: Cooper CS5 at 50 psi, ventectomy, mufflerectomy, LED plate light, upper fiberglass grille block, front lower pan, front fairing.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
The Following 4 Users Say Thank You to deejaaa For This Useful Post:
BamZipPow (12-08-2015), mikeyjd (09-21-2013), NachtRitter (09-22-2013), UltArc (09-22-2013)
