92 vx honda distributor replacement - OEM or After?
My distributor needs replacing on my vx. Should I stick with OEM on this part or should I go with an aftermarket one? I'm not sure if one would be better than the other for reliability and efficiency. Granted the OEM ones are quite expensive. What are your thoughts on OEM vs. After market for this part?
This is the part number: 30100-P08-006
