Old 09-22-2013, 07:17 AM   #226 (permalink)
russatt
Ok thanks.
I was also considering a high power 12v charger, and then charging the batteries in parallel, so that they can equalize, but I am not sure if it will be safe with the batteries in series as well, contactor open, and what diodes and components would also be required.
This charger is 12v 320 amps max. Adjustable.
Would it work, or is this a bad idea.
