Old 09-22-2013, 12:14 PM   #6 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
I'm also needing a computer that will run the transmission without the other engine sensors cause they'll be removed also(except for crankshaft sensor of course).
I was asking about your transmission. lol
I should of been more clearer. The TCU "transmission control unit"
This is the one I'm using. Automatic Dsm's
It gives you control over shift points, line pressure etc.
If your jeep has a separate computer to run the transmission you should be OK to run with out a ECU.
Pressure Gradient Force
The Positive Side of the Number Line
