What angle will you try? And how will you prop it open? You could seal the gap with that clear plastic they use to wrap pallets-loads for shipping. I think you could stretch it and layer it and make a custom U-shaped or O-shaped part. Then clip it to the inner lip of the opening. ..or maybe coroplast.
You could just run it open, like a wing over a pickup bed, even though it's sub-optimal; but the carbon monoxide and the base pressure pulling on everything in the interior are reasons not to.
