Originally Posted by jyanof
There isn't a software parameter that affects inductive voltage spikes.
speaking of capacitors, I don't see any in your picture... are they just hidden in the picture?
My capacitors are the same as originall coguar in the picture top left green and black tape conected by wieres with B- and B+ with power board.
Coul you tell me more about snubber, like an RC snubber what parametrs I could try?
My problem
at the moment is that controler works with 100A battery limits when I have incresed current to 200A mosfets blown up and get short circuit
I gave the same time production line mosfets but :
- maybe I need compare the gates capacitance more carefully acording to time of open mybe I can build special tool to check speeds of mosfets?
-or maybe it is something wrong with control board or software parametrs ???
my vehicle is 3300 lb 88V and
motor 13,5 kW series 200Amps; 3300lb weight, 6kp ki30 tposgain17 t pwm gain9 c-rr 6
