Old 09-23-2013, 11:14 AM   #4 (permalink)
RedDevil
90 day: 56.29 mpg (US)
Heh. I was wondering whether I could use the heating plate of an old coffee brewer as a cheapo block heater.
I meant to use it as a contact heater only, but maybe it can be used to pipe-heat the coolant too.
Most likely I'll stay away from messing with it like this until the warranty has expired
After all, I'm not that keen on using some home-built high voltage contraption in an environment that may have volatile and explosive gases.
