Old 09-23-2013, 01:29 PM   #13 (permalink)
Vekke
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Project is officially started .
Weight of those 15" wheels 5.8 kg per piece.
Aerodynamic & rolling resistance, power & MPG calculator - EcoModder.com
Rough calculations of the project first with only diesel powertrain.
On lupo 3l you can reach 3 liters at 100 km/h speed with 1.2 TDI.
Lupo weights 950 kg with driver and A8 target weight 1500 kg = 36,7% difference in weight every 10% increase is 2-4% on highway --> max 14,7% higher fuel consumption
Lupo 3l CdA 0,29*2,0=0,58 Audi A8 modded 0,23*2,2=0,506 = A8 is 12,7% better so 12,7% less fuel consumption on highway speeds
That means I should try to keep the gear ratios pretty close to same as in my Lupo 3l gearbox. That is one reason behind that I will first test 195/65R15 tires. Other is weight savings and ofcourse the frontal area gets smaller.
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
