Old 09-23-2013, 06:09 PM   #100 (permalink)
mechman600
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
Originally Posted by TurnNBurn View Post
As you can see, I'm having issues with the chain rubbing on that lower part of the frame. Any advice on how I can avoid that? This is with the chain fully tense and with the master link inserted, but not completely clipped.
Probably not a big deal being on the unloaded side of the chain. Ryland's suggestion is good. Even a simple plastic guide would be good enough on the unloaded side, the same as most motorcycles use along the top of the swing arm to guide the chain during decel.
Nice build!
