Old 09-24-2013, 01:33 AM   #20 (permalink)
sheepdog 44
I'll try to upload a picture tomorrow of my setup. I use the same exact mirror. What you do is pop out the walmart mirror from the base. Drill a hole through the center of the plastic piece. Get a 1 1/4" pipe clamp? Bolt one end of the clamp to the mirror, bolt the other end of the clamp to the stock bolts (underneath the triangular mirror cover that you have to remove) that hold in the window run channel.
The drivers side interior mirror view is fantastic. Equal if not better than the stock outside mirrors. The passenger side interior is "ok," not as great.
There's a guy that uses a wide angle rear view mirror. It's about $20, but it's really professional and gives a great view out the passenger side.
BTW, what state do you live in? Some states are a bit iffy on mirrors.
I try to be helpful. I'm not an expert.
