Old 09-25-2013, 11:19 AM   #4 (permalink)
meelis11
meelis11's Avatar
Green frog - '97 Audi A4 Avant 1.9TDI 81kW
Diesel
90 day: 43.1 mpg (US)
Why dont you use it with your OBD2 car?
I have OBD2 car with factory computer and I am still using mpguino It gives much more info and mpguino is accurate for measuring fuel economy. Factory computer is too optimistic.
edit: seems that you use ScanGauge now. Anyway - if you want to fool some sensors then mpguino is better for testing - it measures fuel use, not try to calculate it using sensor reading. ScanGauge can give you false readings if you manipulate/fool sensors (or sensor is just defective and gives false info) that it uses for mpg calcualtions.
http://mpguino.wiseman.ee/eng - get assembled mpguino from here!
The Following User Says Thank You to meelis11 For This Useful Post:
t vago (09-25-2013)
