Old 09-25-2013, 06:44 PM   #12 (permalink)
julien.decharentenay
Thanks a lot for the info. I seem to understand that your best practice are derived from experience, rather than taken from literature - although most looks pretty much common sense. Is this correct?
A quick question on the Ahmed body. My understanding is that the measurements are focused on the pressure in the rear body (particularly on flow field vs rear angle and flow detachment). How are you fining correlation between k-omega SST and experiment? I was under the impression that the "standard" was linear k-epsilon with non-equilibrium wall function. What is your experience?
