Old 09-25-2013, 06:54 PM   #17 (permalink)
user removed
I had an Austin Healey Sprite that had two burnt valves with practically no compression on two of four cylinders. Absolutely gutless running on two cylinders.
I would do a whole lot or research on this proposed desgin before I started hacking up a decent vehicle. To equal the pressure created by combustion you will need about 7 times the compression pressure, 12-1400 PSI would empty a 3000 PSI CO2 bottle in a very short time.
regards
Mech
