A temperature drop will definitely cause higher fuel consumption, due to:
- The engine needing more time to reach normal operating temperature,
- The air being more dense, hence higher air resistance,
- The tire pressure sagging due to lower temp, causing higher rolling resistance;
- The tire flexibility lessens with cold, again higher rolling resistance;
- More friction from relatively cold transmission oil and bearing grease etc.;
- The fuel mixture will be adapted to weather conditions, so winter gas is more volatile and less dense so less energetic than summer gas;
- Heavier traffic as the schools have begun again;
- The school run itself (it has an effect on my FE for sure);
- Helping out Santa
How in hell did you keep your FE within just a 4% drop?
