Old 09-27-2013, 10:59 PM   #33 (permalink)
slownugly
Burn lean and prosper\\//
VLX - '93 Honda Civic VLX
90 day: 51.1 mpg (US)
Is ur evacuation on the performance engine or the lean burn one? I often thought about doing an evacuation like I did on my gremlin drag car. From the crankcase into the exhaust downstream with an anti backfire valve. Does it make a noticeable difference the way you ran it? I've only ever see crankcase evacuations run into the exhaust
Burn lean and prosper \\ //
