Old 09-28-2013, 03:54 AM   #18 (permalink)
Occasionally6
The variations of CVT that I can recall how it is done (at least sort of) are DAF and snowmobiles, which use a centrifugal clutch to engage the drive. The other - Nissan? or Ford/FIAT? - which uses an electromagnetic powder that locks solid when an electric current passes through it to connect engine and trans. together.
At a guess, some may use a conventional torque converter, probably with a lock up clutch or maybe just the clutch part like the internal clutches in an epicyclic transmission.
