Old 09-28-2013, 02:30 PM   #38 (permalink)
slownugly
Burn lean and prosper\\//
VLX - '93 Honda Civic VLX
90 day: 51.1 mpg (US)
Nope that elbow that goes through the intake looks exactly like a pcv but the vxs were open from the factory. No guts in them. The story is people would take their vxs to a mechanic, the mechanic would do the old shake test to the pcv valve not knowing they were empty. It would fail the shake test so they would install a pcv valve that had the guts. This is what I've read on this site. I cleaned the guts out of both my lean burn engines. Maybe someone has a known original to confirm. I have 2 spare z1s laying around I'll have to look when I get to work.
Also I believe all civics this generation had that black oil baffle in the back as well as the pcv going up the intake. Only difference was the open pcv valve.
Burn lean and prosper \\ //
