So I FINALLY checked the codes with my UG. P1456, and P1163.
P1456 on IC net.
P1456 is indeed called the loose gas cap code.
More specifically its Evap leak, fuel tank area. In some unusual cases other more expensive items have (usually) been damaged.
I believe it is from running the tank so low. Will now be filling up at around a quarter tank left, at least shooting for that. I will make sure I fill up by 1-2 bars, at the very latest.
P1163 on IC net.
But the fault and fix still lies with the EGR valve.
This suggests the EGR valve, so I may have an actual issue with the EGRv. I cleared them, and will see how it works out. I may be learning how to clean my EGRv soon!
Are those other images working?
