Old 09-29-2013, 10:14 AM   #33 (permalink)
UltArc
Hydrogen > EV
Silver Flea - '05 Honda Insight
90 day: 58.96 mpg (US)
This is the reference I will be using.
http://ecomodder.com/forum/showthrea...tml#post159596
1. Remove the rear wiper arm. There's a 10mm nut holding it in place, and with it gone, the arm can be worked loose by wiggling it back and forth a little.
2. Remove the wiper motor. Pull off the grey plastic interior hatch trim piece and discard it if you like. Unbolt the three 10mm bolts holding the motor in place, unplug its cord, and remove it from the car.
3. Plug the hole in the hatch glass. I used a plug from Lowe's misc. hardware drawer. Unfortunately, the size I needed (1+3/16" or 1+1/4" iirc) is only available in chrome, so I had to sand it until the chrome was rough so I could spray-paint it black. Install it with some silicone.
Getting started!
Best Tanks:
Mustang - 54.83 mpg (US) at the Green Grand Prix
Insight - 82.91966 mpg (US) over 818.5 miles.
