Old 09-29-2013, 11:25 AM   #34 (permalink)
Insight for life
Insight for life's Avatar
05 Prius (wife's) - '05 Toyota Prius package 5
90 day: 44.32 mpg (US)
Citrus - '00 Honda Insight
Gen-1 Insights
90 day: 60.68 mpg (US)
Originally Posted by UltArc View Post
This is the reference I will be using.
http://ecomodder.com/forum/showthrea...tml#post159596
Getting started!
looks good. pulling the gray trim off requires some strategy at times, obviously make sure you pull it straight out toward the front of the car. also here is a link to the sink hole cover. its basically this but you can get it in white plastic and it comes with a gasket and sturdier mounting system, Shop Danco Metal Sink Hole Cover at Lowes.com
P.S. the plastic one also has too long of a mounting base so it has to be cut a little shorter for the trim plastic to go back on. but i really do recommend the plastic one.
