Old 09-29-2013, 06:37 PM   #1110 (permalink)
Occasionally6
Originally Posted by TheEnemy View Post
Occasionally: Find me an example of a climate model that both fits the past and can be used to project an idea of the future done by the experts that is done the way you say mine should do. Make sure that we can also dive into the equations and see how it works if you can.
Try the models matched against Pliocene data (the particular models used are in the article and papers) I made reference to in an earlier post. Those are among the same models used to predict future climate.
Modelling the Pliocene was used as a check of both Pliocene climate data and the models, as well as increasing the understanding of the Pliocene climate.
Models can be accurate or not. I have seen a model generated FEA graphic of a virtual barrier crash test of a car put up against the real world test result. Maybe they were carefully selected images but the similarity was remarkable.
