Old 09-30-2013, 12:18 AM   #1 (permalink)
stovie
the green machine :P - '97 Jeep Grand Cherokee ZJ
90 day: 20.92 mpg (US)
Thee s10 - '00 Chevy S10
90 day: 24.27 mpg (US)
Freedom - '05 Kawasaki Ninja 250EX
90 day: 75.55 mpg (US)
Safe compression ratio?
Ok what's the highest compression ratio you can hit with a stock engine before needing reinforcement?? I was looking on line about ethanol and other fuels like it, and they say that if you can hit like 14.5-1 cr you'd get better FE out of them then with gasoline but I've been told that if you did that to a stock engine you'd blow the pistons out the bottom or else destroy your main bearings really fast. Any ideas??
The Following User Says Thank You to stovie For This Useful Post:
Allch Chcar (09-30-2013)
