Thread: Wheels choice
Old 09-30-2013, 01:05 PM   #5 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by renault_megane_dci View Post
Stick with the 195 65 R15 wheels where I intend to have the least RR tire available (namely Bridgestone Ecopia EP001s) on the rear only (the front have some thread left)
Those are A A rated, aren't they ?
Nokian seem to have pulled the plug on their eLine A rated tyre ... they're no longer on their website ?
Retrofit the 205 50 R17 wheels I had previously but with 205 55 R17 for a significant (?) 4.8% increase in perimeter.
I wouldn't go wider if you're after top FE, nor would I get bigger wheels - unless you're willing to invest serious money in very light rims.
Eco tyre availability in 205/55/17 is even worse than in 205/50/17 (which are very expensive).
You'd end up with a heavier wheel+tyre combination, and couldn't get the best rolling tyres for it.
You'd be losing FE @ both ends.
I'd stick with the 15" and get the best rated tyres for them.
If possible with a higher LI than what you actually need so the sidewalls are stiffer.
