Old 10-01-2013, 12:48 PM   #17 (permalink)
Xist
Originally Posted by Sam Powell View Post
From what I have read, it kind of depends on how smooth the bottom of your car is. If it is smooth, the strategy is to get the air to flow smoothly between the wheels. If it is not smooth, then you try to get it outside the wheels and around the car. Then the challenge is getting the air to come back together smoothly with minimum drag at the back. That kind of depends on what you did at the front, and the shape of the rear. I would like to hear others' thoughts on this.
Sam
I have read repeatedly on here that only minimal improvements to aerodynamics can be achieved with the front, while the greatest difference can be had through the back. Grill blocks and air dams work. People think that nosecones will make a car more aerodynamic. They just make things worse in a cross-wind. A Kamm-back or better yet a boat-tail will allow the air to stay attached longer, leave a smaller wake, resulting in less drag.
