The radio shutting off when cranking is not a problem.
The radio is supposed to shut off when cranking. It is switched to do so.
This is because the inductive current draw from the starter can put a massive voltage spike into the electrical system when cranking stops. By shutting off electrical accessories that are sensitive to power spikes, the manufacturer avoids the chance of damaging them.
