Old 10-01-2013, 07:48 PM   #30 (permalink)
Xist
Originally Posted by SentraSE-R View Post
Xist, I found your post at subaruforester.org. You and jayliu1984 need to set up your devices (Ultra-gauges or Scangauges) to recognize DFCO. The UG EM v. 1.2 Injector Cutoff setup procedure is on page 50 of the Owners Manual.
MENU  UltraGauge Setup ..  Injector Cutoff
The SGII v. 6.0 fuel cutoff setup procedure is on page 16 of that Owners Manual.
Once you get your UG or SGII set up to recognize DFCO fuel cutoff correctly, you'll start seeing 0 fuel consumption, or 9999 mpg.
If you rely on a mfr OEM fuel consumption display (as I suspect jazyliu1984 may be doing), you're likely SOL.
Sorry, this is an old post, but somehow I missed it, and then happened to see it again recently. Thanks for pointing this out to me!
