Old 10-02-2013, 11:42 AM   #27 (permalink)
liquidzorch
Originally Posted by slownugly View Post
Are you throwing it in neutral when coasting down hill? Leaving it in gear is the better route because it activates dfco. Idling in neutral when coastin uses fuel in these cars. When approaching lights or stop signs downshift without touching the gas pedal.
My stock 93 lx consistently got 40 mpg highway. That's not at 5000 feet but you still should yield better than low 30s.
This week I have been trying with leaving it in gear downhill, and downshifting to stop. But still have not seen much improvement. It has helped a little, but it has not helped enough to raise a whole number in mpg.
I would like to find the fault for this, I will be buying new injectors soon, and check that since one of my injector leaks a little bit when off. It has been tested and they say it does not inject more that the others, but still, hopefully it will help a bit.
