Old 10-02-2013, 06:17 PM   #6 (permalink)
Tesla
The Truck - '02 Nissan GU Patrol ST
Originally Posted by whatmaycome14 View Post
This is quite the demanding and time consuming task! I've started though...
I used duct tape and expansion joint foam, or yoga/camp mat type of foam.
In some areas where gaps were irregular, like behind headlights, I used softer foam over the entire area, then stuffed in cushioning behind it and also used those water bladders from boxed water, just pushed them into the area then inflated to fill the gaps.
