Grille/no grille block??
I just had an idea I wanted to pass by every one. What if on the grille block you spaced it 1/2" off the grille so that if it's head on into the on coming air it smooths the air around the grille but the fan can suck air in around it at the same time?? I understand that cars with grilles at a backwards slant won't work very good but maybe on thoughs have the end towards the wind flat to the grille and the side away have a 1/2" to 1" space for air inlet?? Just something that popped in my head earlier that I wanted some input on! Thanks!!
