Old 10-02-2013, 09:10 PM   #5 (permalink)
Formula413
Renaissance Man
Formula413's Avatar
Aegean C - '17 Honda Civic LX
90 day: 39.05 mpg (US)
One thing I will add to that: Instead of cutting the green wire, it is easy enough to remove that wire from the connector. The plug comes apart and the terminal can be removed by using a very small screwdriver to depress the small tab inside the connector holding the terminal for the green wire in place.
